HELP!!! I'm Burning Up!!! Very Scary CPU and GPU Temps :'(
Last response: in Systems
- CPU and GPU temps very odd performance? Please Help! - Forum
- CPU and GPU temps are very high - Forum
- PSU keeps on burning and computer gpu and cpu stay very hot and pc sme - Forum
- CPU Temps Get EXTREMELY Hot Very Fast When Playing Games! Help! - Forum
- Buying a new motherboard and CPU - But I'm very new to this, could use some help! - Forum
- System locks up at anything except very low temps. Motherboard or CPU faulty? Forum
- SolvedI'm helping a friend build a computer for editing using Adobe Premier. Should I focus on finding a good GPU or a good CPU? Forum
- I have an HP Envy 17 laptop with i5 dual core the temp is showing very high CPU: max 144 avg 102 and for GPU Max: 128 Avg: 92 Forum
- SolvedNvidia GeForce GT 630M reaching up to 95 degrees, need easy to use software which can help manage my GPU (CPU if possible) Forum
- GPU too close to CPU? Causing problems? Please help! CPU temps over 98C!!! Forum
- Motherboard z87m-plus hight temp, CPU and GPU very low, case cool Forum
- SolvedClearance issues cpu cooler and gpu. HELP I'm desperate. Forum
- Very High Cpu temp plz help Forum
- Cpu/Gpu Temps Hot???? plz help Forum
- gpu cpu temp paranoia plz help me :) Forum
- GPU AND CPU temp while gaming ? help Forum
- Cpu and GPU matchup -very noob requesting help Forum
- Im helping my friend up grading his cpu but i need help Forum
- My CPU and /gpu temp. Help please Forum
- Need Help! Having Temp Issues with CPU/GPU Forum
- More resources
