Dual Channel Memory..Using 2 different sets with different timings?
Last response: in Memory
December 29, 2010 4:45:17 AM
I had 8gb of ram (4 x 2gb sticks). 1 stick recently went bad. I can only buy this ram in pairs, so I see no reason to buy 2 sticks when I don't need it.
Instead I would prefer to buy 8gb (2 x 4gb). Problem is this ram has different timings.
Will there be any negatives to having each set of ram run on different timings?
I know my BIOS allows me to set each dual channel setup with different timings...
I ahve
a b } Memory
December 29, 2010 12:06:42 PM
Actually, you will likely have to run all the RAM at the settings of the lesser RAM: the higher latencies of the two sets and the lower voltage of the two sets. Try to get RAM that matches your existing speed (MHz).
m
l
