Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > $1600 CPU/monitor need final thoughts
Forum Systems : New Build $1600 CPU/monitor need final thoughts
APPROXIMATE PURCHASE DATE: no real deadline; before the unannounced Cataclysm lol
BUDGET RANGE: (budget is maxed at 1200) total at purchase
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: (I have a netbook to serf the net and download…everything I download goes straight to an external TB hard drive. This CPU would be used for gaming; specifically I want to play World of Warcraft, Just Cause 2, Command and Conquer series, and ALL of the Total War series. I would like to run WOW on the highest graphic settings; no shadows though. As for the other games they won’t need to play on max settings, but I want to enjoy the gameplay)
PARTS NOT REQUIRED: software... although I will be using Windows 7
PREFERRED WEBSITE(S) FOR PARTS: (I would like to buy as many parts from manufacturers, I would not mind newegg.com, ncix.com, tigerdirect.com, or any sTorE in NYC (might be cheap?) IT WOULD BE NICE TO BE ABLE TO CONFIGURE ON A SITE, as I have no idea how to construct a CPU
-- to show us selection & pricing) COUNTRY OF ORIGIN: (NYC, USA)
PARTS PREFERENCES: (I would like to use an Intel CPU & ATI video card – I know I can’t get the best or newest models but from what I have read these would be better for games) .... the i5 750 and the ATI HD 5000 series are musts...
OVERCLOCKING: Would like too SLI OR CROSSFIRE: in the future
MONITOR RESOLUTION: I believe 1920x1080 - is the LED for Samsung so ya
ADDITIONAL COMMENTS: (I really want to spend my summer in front of a high performance computer…6 years ago I bought an alienware laptop and I loved World of Warcraft on it. Two years ago it busted and so did my WoW career, but it’s about to be summer and I think I have the time and capital to get back into the game…I have read and ‘’configured’’ tons of CPU’s “ONLINE” but I keep going over budget and I know it can be done for 1200)
I just found this website and there isn’t enough time in the day to go through all of this great info without making a post to see if I can attract the info I require. I read most of the posts on CPU’s and WoW and I would like to work this out before I copout and buy a premade:: I would like a quiet PC, I would like a cool looking case, I want to spend most of my budget on ram, cpu, and video card.. )
THANKS
in
ADVANCE
Message edited by retrodebate on 05-13-2010 at 01:43:47 AM
Reply to retrodebate
Off hand (at a glance) ...
Downgrade your CPU and upgrade your GPU ... You want a Hard-Gaming HTPC.
------------------------------ = Alvin =
Reply to Alvin Smith
Ok so is a GPU a graphics adapter? Is that separate from a video card? If it is a video card; research indicates the ATI 5770 is a more than good card... I'm still researching though. What CPU do you suggest?
Also it would NEED WIFI as I need to connect to house wireless...from what I have seen this very possible with a wireless card..
- 1 +
^^ Yes they all mean the same...
And as for the HD 5770, yes no doubt is more than a good card, but for 1080p resolution, if you dont want to have that occasional drop in frames/ lag, then better to get a more powerful card and also you will be sticking with 1 card so more powerful, the longer its life(in terms of performance)
And as for the CPU, for WoW and in general gaming, the i7 9xx doesnt have any significant performance improvement over the new i5 750...It is also a Quad and is powerful enough for any games out there...
Here is a total config, just in case you plan to buy it separately...
i5 750
http://www.newegg.com/Product/Prod [...] 6819115215
Mobo - With SATA 6GB/s and USB 3.0
http://www.newegg.com/Product/Prod [...] 6813128412
Video card -
HD 5850
http://www.newegg.com/Product/Prod [...] 6814161330
http://www.newegg.com/Product/Prod [...] 6814125318
http://www.newegg.com/Product/Prod [...] 6814102885
RAM -
GSKillz 4GB DDR3
http://www.newegg.com/Product/Prod [...] 6820231274
PSU
http://www.newegg.com/Product/Prod [...] D046%2DS01
HDD - Samsung F3 500GB
http://www.newegg.com/Product/Prod [...] 6822152181
CASE -
http://www.newegg.com/Product/Prod [...] 2D073%2DTS
WiFi
http://www.newegg.com/Product/Prod [...] -_-Product
Reply to gkay09
In regards to the WiFi, I need one that can pick up signal from two floors up. I really like the one you linked (150m range), I just want to make sure it's strong enough. It is also a USB model..is there a specific reason as to why you suggest a USB instead of an internal card?
I'm going a little heavier on the GPU than the above build (which is decent). Here's what I would build:
CPU/Mobo: i5-750 and Asus P7P55D-E Pro $375
RAM/GPU: G.Skill Ripjaws 2x2 GB 1600 mhz CAS Latency 7 and HD 5870 $490
HDD: Seagate 7200.12 500 GB $55
PSU: Antec Earthwatts 750W $85 after rebate
Case: HAF 922 $80 after rebate
Optical: Cheap SATA DVD burner $22
HSF (if OC): Coolermaster Hyper 212 Plus $35 (with free card reader)
Total: $1,147
To answer some of the questions in the original post...
Overclocking: This is a cheap way to get more power out of the build. Generally, it's recommended to at least be considered at some point.
Crossfire: This is a good thing to have for future proofing. Games quickly require more graphics power to run at decent speeds. Typically, that means you have to replace the GPU at regular intervals. However, with Crossfire, instead of having to buy a very expensive large GPU to continue to play new games, you can buy a cheaper, older card and get the same performance. So the ability to add the second card allows you to get cheaper upgrades down the line.
Wifi: A USB wireless receiver is good because they're cheap, easily transferred to a new computer and don't lose anything in performance.
Finally, I strongly suggest you consider building it yourself. PCs are very easy to build on your own nowdays. The components only have one way to be put together, and it's almost impossible to do it wrong. Generally, if you're thinking about getting out a hammer, you're doing it wrong. There are thousands (if not millions) of guides on how to build a PC out on the web, so as long as you read through some of them and/or follow one, you'll be sure to get it right. Also, building it yourself gives you a tremendous knowledge of the inner workings of your computer. You know what needs to be tweaked, what needs to be upgraded and if something goes wrong, what needs to be fixed.
If all that wasn't enough, buying a PC that's been put together for you has several drawbacks. If you pick the parts and someone else puts it together, it very likely you get poor build quality and pay a hefty premium for the service. If you buy from a vendor (i.e. IBuyPower, Dell, HP, CyberPower, etc.), you're paying a huge premium and getting lower quality parts.
------------------------------ How to Ask for New Build Advice
Troubleshooting
Reply to MadAdmiral
quick question, I want to go with the crossfire. What additions do you recommend, i.e. can everything here work with a second card and what card would you recommend?
Also, why 4 GB ram.. I'm going to do more research, but all the premades have 6-9GB. Does Ram only help with multitasking?
I can increase the budget in terms of the crossfire, but would need more time.
Message edited by retrodebate on 04-20-2010 at 10:40:53 PM
The build can already do Crossfire. The board and PSU are good enough for it. I would wait until the 5870 is not doing so well in new games and then add a second one. You generally want to match the model (i.e. HD 5870) of the cards for Crossfire, but the brand (i.e. XFX, HIS, Sapphire) doesn't matter.
If you're looking at i7-930 prebuilts, 6 GB is the standard. Unless you're doing heavy computations, 4 GB is more than enough for everyone.
Troubleshooting
Reply to MadAdmiral
Ok one note that I won't have to retract ;) ...WoW does not recognize CrossFire. So while having the ability to CrossFire in the future will be useful for other games, or for WoW's successor, don't plan on using it for WoW.
Message edited by coldsleep on 04-20-2010 at 10:55:34 PM
Reply to coldsleep
Well as long as this CPU supports crossfire I'm happy.
As for WoW, Blizzard says it does support it:
http://forums.worldofwarcraft.com/ [...] 0220&sid=1
Also, I know crossfire will work for Total War and Command and Conquer.
Also, will this CPU optimize the visuals a LED 23'' at 1920x1080. Would i use a DVI, VGA, OR HDMI cable from the CPU to the monitor?
Agh. Old information again, I guess? Sorry. :/
Reply to coldsleep
The CPU won't have anything to do with the visuals. That's the GPU. And yes.
You'd want to be using the HDMI cable from the graphics card.
Troubleshooting
Reply to MadAdmiral
- 0 +
@retrodebate the CPU doesnt have to do anything with the Crossfire/ SLI...It depends on the mobo(it should have 2x PCIe x8/ x16 slots and not 1x x16 and 1x x4 slot) and PSU(should have enough power to run 2 cards)
And as for the visuals, it depends more on the Graphics card than the CPU...but even the CPU has a major role to play at high resolutions because it should be able to cope up with the powerful cards...
So generally it is advisable to go with a powerful CPU(Preferably Quad) if you will be running multiple card configurations(2x HD 5850s and so on...)
And if you will surely be doing crossfire, then stick with HD 5850 rather than HD 5870 as the stock speeds of the i5 750 might not be able to cope up with the power of 2x HD 5870s...
But if it highly doubtful that you will be doing Crossfire, then stick with the PSUs that I had listed and spend more and get the HD 5870...It will last longer in terms of performance...
And 4GB is good enough for gaming and anything more doesnt have any significant effect on games...People go with 6GB only on LGA 1366 mobos as the CPUs have Tri-Channel controller - 3/ 6 sticks...
Reply to gkay09
http://www.youtube.com/watch?v=fECWSSpEVVA... Would this be possible with this setup? My budget just went up.. :)
So the question is would this CPU be able to handle triple or dual monitors in the future? I understand that I would need peripherals later down the road for the monitor setup...but I think I will eventually make that kind of commitment. So, if at possible what modifications would I need to go ahead with this? I would like to purchase the parts before the end of May :)
Message edited by retrodebate on 04-22-2010 at 08:48:45 PM
Also, is there any reason why I should not want to make this kind of system?
Once again, I will point out that the CPU has nothing to do with the graphics. The GPU determines all of that. The 5870 can handle up to three monitors (six if you get the Eyefinity 6 version).
The issues with Eyefinity setups is that you lose a LOT of FPS in doing it. Yes, it looks cool. However, the GPU power required is going to cost you a lot of money to do it right.
I can't watch that video (I'm at work), so I can't comment on the actual setup in it.
Troubleshooting
Reply to MadAdmiral
Great! Would only want 3 monitors max. Oh and when I have mention ''CPU'' I usually mean the whole thing; the tower really or CPU > Laptop > Netbook. I should be saying desktop. This is great though. I really like the idea of being able to see that much of game.
I would like to know if these towers are workable?
APEVIA X-CRUISER2-GN Green SECC Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811144243
APEVIA X-TELSTAR-JR G-Type X-TSJGT-BL Blue SECC Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811144211
Is this an acceptable? The $1,629.85 price is somewhat appeasing... Any input?
This monitor is my picking:
Samsung Syncmaster 2233RZ Black 22" 5ms 3D Gaming 120 Hz Widescreen LCD Monitor 300 cd/m2 DC 20000:1 w/ HDCP Support http://www.newegg.com/Product/Prod [...] 6824001311
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Prod [...] 6827135204
COOLER MASTER COSMOS 1000 RC-1000-KSN1-GP Black/ Silver Steel ATX Full Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811119138
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822148395
COOLER MASTER Hyper 212
http://www.newegg.com/Product/Prod [...] 6835103065
XFX HD-587A-ZND9 Radeon HD 5870 (Cypress XT) 1GB XXX Edition 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card http://www.newegg.com/Product/Prod [...] 6814150456
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Prod [...] 63938&SID=
Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Comb [...] mbo.369221
Antec EarthWatts EA750 750W Continuous Power ATX12V version 2.3 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC "compatible with Core i7/Core i5" Power Supply
http://www.newegg.com/Product/Prod [...] 6817371026
ASUS USB-N13 USB 2.0 Wireless Adapter
http://www.newegg.com/Product/Prod [...] 6833320040
Message edited by retrodebate on 05-13-2010 at 01:41:06 AM
Also around XMAS 2010 I plan on going CrossFire with another HD 5870 and adding TripleHead2Go with two more 23 LED Samsung monitors... is this a good build for those changes? This is a definite, so I would need to be able to accommodate. I'm sure I need a ATI Eyefinity don't I? So anyone know better prices... going to post links. Also, is this mobo compatible with a Crossfire set up?
Message edited by retrodebate on 05-10-2010 at 12:22:11 AM
Is everyone busy? Or did I run out of Disney $$$ dollars?
Thanks. I read the reviews on a lot of the USB wi-fi adapters and they don't seem to speak highly of them. I will probably go with an internal adapter, but would have to confirm that it will not conflict with the tower available ports or even the ?mobo? I haven't been able to do much researching, due to my exams and papers I've been busy. I like what the reviews of the links you posted. Most of my gaming will be online games, so I really want the best wi-fi adapter and would be willing to shell out the cheddar for a good one.
Anyone have any tips on my links above^^^^I would like to know if those parts are good; most are from MadAdmiral's links. I would like to know about the tower in particular.
Thanks in Advance.
I used to have a belkin n wireless adapter very much like this one http://www.newegg.com/Product/Prod [...] -_-Product
The connection is amazing, but as the reviews state the drivers f*** SUCK!!! If you get it working though it'll be great.
secondly IMO thats a lot of graphics power for comparetively little cpu power. I would suggest if you add a second card in several months anyways to go for an i7 930 system with a 470 gtx(this would only be if you certainly add another card otherwise I'd stick with the current setup.)
An i7 system will increase cpu power(obviously), increase ram speed quite drastically(since its tripple channel) and cost you about 100dollars more(considering the 50dollars less for the gpu).
------------------------------ i7 930 - Lian li a71f - aerocool v12xt - 850hx - 470gtx - ga x58a ud5 - 640gb WB black in raid0 + 2x2tb - nh d14 - 6gb redline enhanced 1600 cl6
Reply to Somebody_007
Headache...so many articles on the web. Any recommendation on forums or threads that can help me building a SLI/CX ready system that can support three monitors? I've been to widescreengamingforum.com and there is a ton there, but not much on building a cpu.. I want to stay in my budget. My newegg.com cart is $1500 including monitor and it will take another month before I will have that kinda coin. Thanks in advance.
http://www.tomshardware.co.uk/foru [...] e-building this is a pretty good guide its the one I used.
In regards to parts I have listed above is everything compatible? Also would it support dual video card setup? Would it support a triple monitor setup? Or do I need Eyefinity cards? I plan on buying parts at the end of the month, so I want to get some confirmation. I have had no feedback on the RAM or the case, so that would help too.
The parts are compatible. It will support a dual-card setup. A single 5870 will support a triple-monitor setup, though you will need a DisplayPort to DVI (or HDMI) converter if you don't have a monitor that supports DisplayPort input. You do not need an Eyefinity edition, in most cases that would make things more difficult, as those versions only have 6x DisplayPort output.
OCZ is not frequently recommended around here due to reports of needing to over-volt the RAM to get it to work at specified settings. This G.Skill Ripjaws 4 GB kit has faster timings and is only $10 more. This G.Skill ECO 4 GB kit is a couple bucks more with shipping but has the same timings as the Ripjaws and runs at a lower voltage.
Case is largely personal preference. Many will claim that you're paying too much for that case. If you're satified with it, and if the manufacturer's website says it will fit a 5870 (and a full tower should, most of the time), you should be good to go.
Reply to coldsleep
Ok I have picked up the Ripjaws. I have a question about a GPU. I want the 5870 but don't know which brand or which model to get... or if the models with the 2.1 PCI Express are preferable. So for 400 I want to know which is Tom's recommendation.
Is there a thread on the best parts based on price ranges?
Not really. For the most part, all of the 5870s are the same, the primary differences in brand are warranty/support. There has only just begun to be any variation in the models, and that's mostly the models that are $430 and up.
Generally, Sapphire and XFX are seen as the two top-end brands due to longevity & customer support (Sapphire) and warranty (XFX). I have been reading of complaints about Powercolor customer support recently, but I haven't had any direct experience, so I don't feel qualified to comment on that.
Reply to coldsleep
Both of the 5870's from XFX support eyefinity. Under display ports it indicates that there is 1 for each of them. Also I am only looking at models with HDMI ports. These are the two I like, but there are so many to pick from.
http://www.newegg.com/Product/Prod [...] 150-487-TS
All 5870s support Eyefinity.
I would get the one with the double-lifetime warranty, myself.
Reply to coldsleep
After some reading... HDMI will provide no better picture than a DVI connection. Therefore, I have changed the monitor that I will use for this setup. I know that HDMI sends audio and video, but this will not matter as I am going to no rely on the monitor for audio. The new monitor is included in the above post.
Message edited by retrodebate on 05-13-2010 at 01:44:14 AM
- 0 +
^ The build is fine, but frankly am not much happy with the monitor...and any specific reason for that case ?
Check out this monitor, if you want a 120Hz specifically...
http://www.newegg.com/Product/Prod [...] &Tpk=120Hz
but it wont be much of a use if you will be going with ATI cards(No 3D gaming AFAIK)...And a HD 5870 for 1680X1050?? Not a good idea IMO...If you will be sticking with that Samsung monitor...drop it to HD 5850 - which is still an overkill...
Actually you can save some money with the case, PSU, graphics card...
CM HAF 922 + CM GX750W - Though not as good as a Corsair but very much comparable to the Antec EA750...
http://www.newegg.com/Product/Comb [...] mbo.395128
XFX HD 5870 - IMO $20 for about 25MHz increase ? The CCC itself allows for an overclock of upto 900MHz...So just use that...
http://www.newegg.com/Product/Prod [...] 6814150490
Reply to gkay09
WOW! I did not know that Samsung was not 1920x1080! I like your Acer link over the other Samsung choices. I was hoping to get a Samsung for aesthetics. I have a 32" in my room and I would've like a pair.
My original monitor choice was the Samsung LED, seen here: http://www.newegg.com/Product/Prod [...] 6824001380
oh, and I have no interest in ?3d gaming? I don't plan on doing research on the benefits, as I will not wear glasses in doors (except for a movie theater)
Also, is there any reason to avoid my case? I like the extra fan, and most importantly it is nicer on the eyes. The case is what I will see 100% of the time and after putting work into this system, I would like to enjoy it.
I definitely agree with you on the GPU. Will change above.
- 0 +
^ Well I thought that you wanted a 120Hz because you wanted to go 3D, but if you dont have that plan at all, then very well get that Samsung monitor that you have listed above...It looks pretty slick and nice...
As for the case, you dont like LEDs and stuff?? Except for that I feel with the case such as the 922, the airflow would better because of the bigger fans and also it is perforated on the front...
Reply to gkay09
I'm leaning towards the 922... I see the fan difference now. Also, 50% off right now! I have been looking at these Antec's, which also have some nice choices.
Also, i5-750 = problem with crossfire? I have not found a site confirming this? I wish there was tangible literature on the subject. I subscribed to Maximum PC a month ago and the ETA is another month away before my first issue. Anyway, I would want to crossfire eventually.
- 0 +
Why do you ask i5 750 = problem with crossfire??
Reply to gkay09
There isn't a problem with Crossfire with the i5. You'll be just fine.
You've got a great build with gkay's last changes.
Reply to MadAdmiral
What you've probably heard about is that P55 boards are only capable of 8x/8x in Crossfire, but that only amounts to a very small difference from 16x/16x and only with very large graphics cards. Noting to worry about at all.
Reply to coldsleep
I'm going to get a TB HDD, any thoughts on the SAMSUNG Spinpoint F3 HD?
The Spinpoint F3 is generally considered the best 1 TB performance drive available at the moment. Other very good drives include the Seagate 7200.12 1 TB drive and the Western Digital WD1002FAEX 1 TB SATA III drive.
The Seagate offers equivalent performance at the same or slightly cheaper price. The Western Digital is more expensive and while it has SATA III, mechanical hard drives just don't use the extra bandwidth at the moment, making it hard to justify the price increase vs. the other two drives.
Reply to coldsleep
- 0 +
^ +1...
Though I liked Seagate, but they go it wrong with their 7200.10 and 7200.11 drives...High failure rate...Even the 7200.12 though are far better than the previous gen, but still have above normal failure rates...Just yesterday my friend's Seagate 7200.12 500GB drive gave up on him...dint expect that at all...
On the safer side, better to stick with Samsung for now as their failure rate is far less...
Reply to gkay09
IF ANYONE, has experience with Avadirect.com... let me know. If there is a thread/forum, point me to it... didn't see it. Hey, out of the AVADIRECT.COM ram choices which one is preferable? I think its out of corsair, ocz, mushkin, kingston?
I want to post my cart so I can get comments.. I was advised to not build myself as I have no experience and it's a lot of money to risk..
parts I'm going with are
haf 922
antec ea750
asus p7p55d-e pro
intel core i-750
hyper master 212
kingston 4 2x2 - value ram pc3-106000 ddr3 1333 (I need help here)
xfx radeon 5870
samsung 1tb spinpoint
samsung super-writemaster
network cards ?????? (do i need to get something more than the integrated if im ONLY using WIFI)
pci wireless networks card (do i need to get something more than the integrated if im ONLY using WIFI, i plan on getting a wifi usb)
case fan - do i need to do this?
Message edited by retrodebate on 05-28-2010 at 02:56:58 AM
Plan on buying on Friday :)
Just have questions with the wireless necessities and ram choices ... here is the site to see what I'm talking about {http://diy.avadirect.com/Socket_1156_Core_i7_and_Core_i5_PC_Barebones}. Thanks in advance.
There are 1731 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 2 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
