Recovery problems
Hello,
When I swiched on the desktop, the message \windows\system32\config\system....missing or corrupt
you can attempt to repair this file by starting windows setup using the original setup CD-ROM . Select "R" at the first screen to start repair :
I inserted the original setup CD ROM but it just did not run. The same message came up again. What can I do.
1 answer Last reply
More about recovery problems
  1. Go into your bios and change the boot order so that your CD drive is 1st and your hard drive is second.
Configuration Data Recovery Desktops CD-Rom Windows XP
