Hey guys, first off i dont know if this is the right section for the following but i apologize if it isnt.
I just built my new rig, first time building a comp, and i'd like to make sure my computer is running as it should, so any help would be appreciated.
Specs are as follows:
I7-930 cooled with Corsair h50 water cooler
Asus p6x58d premium mobo
Asus hd 5870
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600(PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D
thermaltake 850W
Corsair 800D case
My first question is in regards to my EATX12V power connector. My thermaltake power supply came with 1 8-pin EATX12V power cable, but due to the fact that the 800D case is a mammoth of a case, it could not reach the top of my mobo where the connector is located, so i used an EATX12V 4-pin cable. I've read online that i7's usually require an 8-pin. Is this true? Is it only true if i want to overclock?(which i do)
Now on to temps.
Here are my current temps, stock speeds at idle, lemme know if it looks about right, thanks.
http://www.uploadscreenshot.com/image/59531/6924148
I ran a Core Damage burn test for 30 minutes and the temps on all cores did not exceed 64C. Can run more tests if needed for definite answers.
Now here are the tabs from CPU-Z, if someone can go over it(especially the ram areas) since im not too good with these numbers and really dont know if they are working as they should it would be real great.
http://www.uploadscreenshot.com/image/59534/4326863 - CPU TAB
http://www.uploadscreenshot.com/image/59535/6655643 - CACHE TAB
http://www.uploadscreenshot.com/image/59536/7570514 - MOBO TAB
http://www.uploadscreenshot.com/image/59537/2014981 - MEMORY TAB
http://www.uploadscreenshot.com/image/59538/3526938 - SPD TAB
http://www.uploadscreenshot.com/image/59540/8365958 - Graphic TAB
Last question, I ran out of places to plug in my fans power...even though i only have like 4-5 fans in there counting the 2 spots being used for the h50. Is there anything i can do because i want to add an additional 4 fans so i can put my h50 in push/pull setup since it doesnt have that yet and also so i can increase the airflow.
Thanks again guys and i apologize if this was not posted in the right area.
Asus hd 5870
thermaltake 850W
Corsair 800D case
Now on to temps.
