POST beep help
Hi
can anyone help me with my pc problem, ive got a home built pc that wont post or boot or display anything, its been playing up recently and now it wont boot at all.
It wont beep unless I remove the memory sticks from the motherboard. When i remove them the pc makes 10 short beeps and then shuts down. Can anyone figure out whats wrong with it? Im suspecting the RAM becuase there are no beeps when the ram is in.
Specs: E6600 core 2 duo, 2gb ddr2 ram, Gigabyte GA-EP45-UD3L motherboard, 850W realpower pro power supply.
The hard drive spins, the motherboard lights that indicate the CPU is working, the power supply seems to be able to power my other computer and the motherboard has just been replaced as i RMAd the previous one thinking it was a motherboard problem. Im not sure if its a graphics card fault or memory card fault or something else. Can anyone help?
Thanks
3 answers Last reply
More about post beep help
  1. I would agree that it would seem to be a RAM issue. Have you tried resetting the BIOS? Have you tried each stick of RAM by itself? Those are the first two things I'd do.
  2. Thanks for the reply, ive tried resetting the CMOS and ive tried using one stick at a time. When I use any of the sticks the pc wont beep at all, when I take out both sticks I get 10 short beeps before it shuts down. Any suggestions?
  3. Sounds like the RAM is faulty. That's weird that both sticks would go bad, though. What RAM do you have? I would RMA the RAM if it has a lifetime warranty. Or you could take this opportunity to upgrade to 4GB and pick up a nice new kit.
    G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBPI-B $114.99
    or
    G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBNT $99.99
    or
    G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ $107.99
Homebuilt Motherboards Systems Product
