Sign-in / Sign-up
Strange problems with new 9800GT Green!
  • Nvidia
  • Games
  • Graphics
Last response: in Graphics Cards
March 27, 2010 12:33:51 PM
Hi,
Bought new Palit 9800GT 1GB DDR3 with a VIP 500W GOLD with dual 18A on 12V rails,Installed it with a fresh install of windows and while installing the drivers the screen goes black and i restarted the PC and installed the driver again ,It works fine and were no problems.After the driver install, I installed the GTA4 finished in minutes ,opened every thing is good,worked fine,wen entered the game no problem the game starts as usual,after some secounds,The surrounding graphics were corrupted.No roads,and buildings,then i saved the game and start from the safe house,Car was running above the road,Nothing touching the ground,What the problem,I installed the factory driver came with it,No heating problem,Bcoz it idles at 42 and does no exceed 45 on playing gta4 .Whats the problem? Working on new asus p5kpl am ps,1 gb ddr2 667 ram,Dual core 2ghz,and a VIP 500W GOLD!
Thanks
More about : strange problems 9800gt green
March 27, 2010 7:35:44 PM
Try re-installing the game. But since you're a regular I think you already tried it. Why did you need a 9800GT Green anyway, you're 500W seems good enough for it.
m
l
a b Î Nvidia
March 27, 2010 9:21:12 PM
Hahaha burned but it isn't the card this time so don't worry it is working fine just patch the game, if using legit copy you will be fine patching all the way up to date. The razor bootleg well you can still patch up to 1.2 or so before new issues shows up. As for the op your avatar sucks! What is it with people and their avatars some just plane suck? =/
m
l
March 28, 2010 2:08:13 AM
I am from kerala,Even 9600gt is not available here,So i ordered a 9800gt 1gb ddr3,When arrived it was a green edition,But i was planning to buy the 9600 gt,Thas y i bot the vip psu,I have a generic 400w psu before,So bought this,We dont fell any decrease in perfomance with the green edn
m
l
March 28, 2010 2:35:34 AM
Oh, then If you can I would suggest finding a GTX 250 or 260 for a little more power if you want to stick with Nvidia. The 250 is the 9800 with a die shrink and added features while the 260 is the next level up. Just follow nforce4max's advice and you should be fine.
m
l
March 28, 2010 2:37:08 AM
What motherboard do you have? Anything before PCI-E 1.1 isn't spec'd to support 75W.
I would download the latest drivers, as factory ones are usually quite old.
m
l
March 28, 2010 2:39:01 AM
ASUS P5KPL AM/PS With Windows 7 Support
m
l
March 28, 2010 2:40:32 AM
ok,i will check with the latest drivers!
m
l
March 28, 2010 2:41:52 AM
But the same was i installed on my lap with Mobility hd4650 1gb ddr3,and runs fine without any problems!
m
l
