New home built computer is restarting about 5 seconds after post.
The system was built last night and didnt seem to have any problems Windows 7 install completed and motherboard\video card drivers installed.
The system was working this morning but suddenly started to cut power and restart. Since then its restarting just after post checks.
Gigabyte x58-UD5
Core i7-930
G skill tri channel ddr3 ram
2 dvd writers (unsure what brand they were stripped from an old computer)
1 Blu-ray player
2 Hdd
Seagate 1.5tb
320gb sata 2 from the old computer
Silverstone Strider Plus ST85F
2 radeon xfx black edition 5850's
Unplugged a usb hard drive.
I have also tried the PC in a different wall outlet (originally connected to a very full power board)
This particular power supply doesnt have a power switch it i have had the PC unplugged from the wall for 20 minutes it lasted for about 10 minutes.
I dont believe thier should be any strain on the power supply its 850watts.
I did have to remove the heat sink from one of the RAM sticks as it wouldn't fit under the Noctua ND14.
The problem may very well be with the RAM module without the heatsink is over heating when i get to it tonight i will remove the module and test without it. i dont think i damaged it removing the heatsink as it worked properly for a good two hours last night before being intentionally shut down.
any other ideas apart from the RAM module faulty\ over heating.
Gigabyte x58-UD5
Core i7-930
1 Blu-ray player
2 Hdd
Seagate 1.5tb
