I just took my gpu out of my older pc to put in my new build, and I reinstalled the drivers for its integrated graphics and it was running fine. Then I took out the upgraded power supply I had put in it to run my gpu and put the original 300W back in it. now when I hit power it started up for a split second then died, the power button led stays on and it does nothing when I press it. I had to unplug it from the wall to make it turn off.
Is the motherboard stuck on a voltage setting from having the gpu in it that this psu can not supply? It was only a Thermaltake 430W that I had in it. I'm gonna swap that back in and see what happens.
