Hello all, I am having a strange problem (if you can call it that) where my 5870 is running in x8 mode. Checked via GPUZ, CPUZ and CCC. I have an Asus P6T SE motherboard and it is 100% in the right slot with no other cards in what so ever. I know it must be a problem with either the card or the mobo but which is the most likely? I have no other parts to test with.
The worst part is those are the only 2 components in my PC that I got 2nd hand so I can't return them. I get 22,000 in 3DMark Vantage with my i7 920 and this card so it looks like performance is ok. My worry is that I want to buy a 5970 so I can go Trifire but would I get a hit in performance with this problem? If it's the mobo then both cards might go x8 but if it's my card then one would be x8 and the 5970 would be x16! Not sure what that would do...if it even worked at all.
Any helpful advice would be most appreciated, I have followed this forum and site for years but only just joined myself. I don't usually get problems I can't solve but this is a weird one. Thanks.
