Hello,
I have an HP that I am trying to fix. One night my pc shut off and when powered on the HP screen would load but would sit there. I spoke to a technician who said that likely the mobo was bad. I drove to the local computer store(over an hour away) and bought a MSI board that fit my processor and installed it when I got home. When I plugged it in there was no sign of power. The light on the PSU lit up but no sounds or fans turned on. I heard sometimes mobos are DOA so I returned the item and got a new one with the same problem. I switched out the RAM cards, put a PSU from a working pc in and even switched out the fans. Is this a processor problem? The store I buy from has a 25% restock fee so I don't want to spend another $160 to replace a possibly good part. Geek Squad (who is much closer) won't touch it for diagnosis unless I can get it to power on.
To save some time:
I am fairly familiar with pc's including hardware so I know the mobo is installed correctly. Both the 24pin and 4 pin psu cords are connected.
I know the processor and graphics card are compatible.
I use an active grounding bracelet on both wrists and work on a rubber topped table.
Both of the PSU's are rated at or above the recommended wattage and the red clip on the back is set correctly.
To save some time:
