Hey all,
Old graphics card evga 9500GT 1GB and my friend flashed it with xfx 9500GT BIOS because he said it wasn't working after he flashed a 5970 while the 9500GT was in. 9500GT no longer appeared in GPU-Z, so he flashed them with XFX BIOS for a 256mb version of a 9500GT. When running the program, it said that it was going to change the BoardID if you pressed y. Friend pressed y, now card is unusable.
When booted, the screen will just flash random colors and bug out. Surely there is a way to reset the BIOS? Maybe EVGA has the original BIOS for the 9500GT 1GB, and that would also change the BoardID back and all will be well?
Thank you.
Thank you.
