Hello I really need some help.
So I was building my wifes new computer and I got all down to powering it up and when I did the power supply blew up with that nice pretty blue flame that they like to do. So I am sending it back RMA to new egg but I have a question for the community.
The Power supply I am sending back is a OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2.
Should I go to best buy and get this
http://www.bestbuy.com/site/Thermaltake+-+430W+TR2+ATX+Power+Supply/9827301.p?id=1218179698427&skuId=9827301
so I can get her PC up and running. And then just use OCZ power supply when I build my PC later this year.
Her system will consist of:
AMD Athlon II 635
GA-880 Motherboard
500gb sata hard drive
320gb pata hard drive
4gb RAM
DVD Burner
I really have no intention of adding a video card but I wanted to keep this an option.
Also for me I do plan on doing a
Phenom II X4 945
GA-880 Motherboard
4gb RAM
DVD Burner
And a video card like a Radeon HD 5770
do you think the 500w supply will be enough for that also do you think the 430w supply is enough for her computer?
AMD Athlon II 635
GA-880 Motherboard
4gb RAM
DVD Burner
Phenom II X4 945
GA-880 Motherboard
4gb RAM
DVD Burner
