I'm building a new system, and ive decided to go with an AMD 955 paired with an ATI 5870, and 4gb of 1600mhz ram. I have been trying to pick my power supply, but i cant make up my mind Ive basically narrowed it to:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=corsair%20750
or
Antec TruePower TP-750 750W Cont Power ATX12V V2.3 / EPS12V V2.91 CrossFire Ready 80 PLUS BRONZE Certified Active PFC
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371025&cm_re=antec_tp-_-17-371-025-_-Product
the price difference is only about 10 dollars, but i just want to go with the best one they are both ATI certified for the 5870
or
