2500$ System advice
Last response: in Systems
Hi
I am looking to buy a new PC since mine doesn't do all the games I want in full graphics
The current PC I have
E6750 @ 2.66
5Gb ram @ 800
275 GTX
P965 DS3 motherboard
New PC is
PowerColor ATI HD 5970
22X DVD Writer SATA
6GB DDR3 3X2GB DDR3-1600
Intel Core i7-930 Bloomfield 2.8GHz
Gigabyte GA-X58A-UD7
Corsair HX1000W Power supply
Western Digital Caviar Black 1TB
Cooler master Cosmos-S Full ATX case
will this greatly improve my gaming, should I wait on some parts, anything i should consider replacing?
Thanks in advance
More about : 2500 system advice
A GTX275 can't handle your games!? GTX275 is a monster card...which resolution are you gaming at? My old, frail, week 8800GTS 640mb can max out most games on 1080p except for like crysis and others. Your 275 should be ripping through anything on 1080p and even higher.
The build you proposed though looks very good i'd say. Seems like you did your research, only thing is which brand of ram are you getting? And also, i'd save some money and not buy the 5970, keep the 275 and see how well it will scale on your build as it can very much be that your CPU is bottlenecking your videocard. If it's still bad, then get the 5970, or consider an nvidia GTX480.
I am using a 1080P screen, but I think the CPU is holding the PC back
I tried Dragon age and it was lagging on the highest setting, also aion in crowded areas
Related ressources
At that budget....
$230 Antec 1200 w/ CP-850 http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
HAF 932 w/ Corsair HX850 would be an equivalent choice.
$520 ASUS P6X58D-E w/ Intel i7-930 http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
Better Board
$200 3 x 2GB Corsair DDR3-1600 CAS 7 http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Low profile heat sinks won't interfere with CPU cooler.
$85 Seagate Barracuda 7200.12 1TB http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$100 CPU Cooler, fans, and doodads. See below
$25 Any DVD writer
$700 Twin Asus ENGTX470/2DI/1280MD5 GTX 470 (Fermi) http://www.newegg.com/Product/Product.aspx?Item=N82E168...
.....or
$640 Twin ASUS EAH5850 DIRECTCU/2DIS/1GD5 HD 5850 http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$1800-$1860
Heat Sink - For performance and ease of installation, the Prolimatech Megahalems well fits both criteria. Mega w/ IC Diamond TIM and twin Scythe PWMfans . ($65 for the HS, $7 for TIM, $11 each for two PWM fans and $7 for a Y cable splitter).
http://www.frozencpu.com/products/8807/cpu-pro-01/Proli...
http://www.frozencpu.com/products/7038/thr-41/Innovatio...
http://www.frozencpu.com/products/10026/fan-639/Scythe_...
http://www.frozencpu.com/products/8418/cab-150/FrozenCP...
Pick one of the top 5 on one of these lists:
http://www.silentpcreview.com/Recommended_Heatsinks
http://www.frostytech.com/top5heatsinks.cfm#INTELHEATSI...
http://benchmarkreviews.com/index.php?option=com_conten...
pick a TIM from the top few here:
http://www.hwreviewlabs.com/index.php?option=com_conten...
http://www.xbitlabs.com/articles/coolers/display/therma...
Nice system, but I would add some remarks:
- you don't need 1000W unless you plan to go Xfire/XLI and OC. Maybe you can save some money - not much, though- and work on a higher efficency zone with your PSU if you reduce its power.
- if you can wait some 2 weeks, wait and see how Phenom II X6 perform and what's the price. It will hit the market tomorrow and early reviews should follow soon. Chances are that you can get 2 extra cores for free.
BTW, GTX 275 is still a great card.
Ok I decided to keep the GTX275
I have a Corsair TX 750 PSU will this be enough?
So I will buy these for the upgrade
Gigabyte GA-X58A-UD7 or ASUS P6X58D-E
Note : I am not from the US so I can't buy from newegg
Ask the community
