G
Guest
Guest
Taking the following components into consideration, is 120w sufficient power for the proposed system?
1. i7 (800 series) compatible mini itx board: http://www.newegg.com/Product/Produ...gle-_-Motherboards+-+Intel-_-ZOTAC-_-13500043
2. Mid range GPU: http://www.buildyourowncomputer.com/page/B/PROD/96728S
3. SSD and HHD one Intel and the other a 7200 rpm high capacity drive: http://www.newegg.com/Product/Produ...Froogle-_-Solid+State+Disk-_-Intel-_-20167025 and http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Hard+Drives-_-Seagate-_-22148337
I hope that this configuration won't starve any of the components of power. I'm having a difficult time finding any DC-DC/external AC-DC adapter kits that provide above 120 watts.
