Problem with a new motherboard?!
Hi, My friend has recently got a new motherboard,processor and power supply. We connected everything but it wouldn't turn on. However, When I swapped HDLED with Power SW a light turned on at the front of the computer so power is going to the motherboard. Processor is new and so is the Power supply so I'm not sure what the problem is. No fans turn on..Nothing. Could it be a problem with the front of the case and its internal connectors? Thanks
8 answers Last reply
More about problem motherboard
  1. Read the mobo manual for the front panel connectors. What mobo, what CPU, what PSU?
  2. probably got the front pins the wrong way around.. very easy to do. this is my third pc and i still get it wrong lol
  3. Grip with Ping K15 Irons
    Around the green, clean contact is the key, too. Wet greens will grab a spinning ball harder, and slow down a running callaway ft-iq driver. Be a little bolder than you normally would be in chipping for the cup with callaway ft-iz driver.
    Putting is actually easier on wet greens. The greens will run slower than normal, which reduces the effect of break. You'll have putts that are straighter, but which must be hit a little harder to get to the hole with Ping K15 Driver.
    From time to time clean off the soles of your shoes with a little brush or a golf tee. Your cleats can clog up in a hurry, and then you're playing golf on wet ground with nothing your feet can grip with ping k15 irons. ishiner
  4. claire please move your spam away
  5. lol i was confused readying that Claire. And it's a Gigabyte M68M-S2P Rev2 Mobo, Amd Athlon II x2 250 and a new out of the box 750w Gaming PSU With sli/crossfire support. (Forgot name if necessary I can find that out for you later)
  6. And we tried moving all the pins and still nothing turned on ):
  7. First of all, power and reset switches are not polarized.
    Work systematically through our standard checklist and troubleshooting thread:
    http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
    I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
    If not, continue.
    I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
    Breadboard - that will help isolate any kind of case problem you might have.
    http://www.tomshardware.com/forum/262730-31-breadboarding
    Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
    Make sure you plug the CPU power cable in. The system will not boot without it.
    I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
    You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
    If no beeps:
    Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
    At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
    The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
    You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
    http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
    A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
    This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
    If the system beeps:
    If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
    Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
    Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
    At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
    Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
  8. Thankyou. we'll get busy with the breadboard straight away!
Motherboards Power Supplies Processors
