Hi all
I'm having the notorious GPU error message "ATIKMDAG Stopped Responding, Then Recovered" BUT only when I overclock the CPU.
The problem is causing my system to either go on the blink or hang-up (Tom's article refers to it here: http://www.tomshardware.com/reviews/2d-windows-gdi,2539-8.html and it is all over various forums).
I need some help understanding why I get the problem and more importantly, how I'm going to fix it, because it isn't happening when I'm at stock and I don't have low idle clocks at 2D.
See, the thing is, it only happens when I overclock the CPU. The overclock is only to 3.6 gHz to an i5 750 on a Gigabyte P55M-UD2 board, and its stable in everything else like Prime95, IBT, etc. I tested the GPU in Furmark when the CPU is overclocked and it runs 10 minutes no problem. The GPU has not been overclocked and I have new CCC 10.3 installed (same result as 10.2
Other relevant specs: W7 64bit, 212+ cooling, Crucial DDR3 1333 1.5v ram 2 x 2 GB, temps aren't a problem anywhere, all drivers and bios up to date.
I don't get the problem when I'm at stock settings on the mobo and CPU, and the problem only occurs in the 2D environment i.e. at the desktop.
Most people who have solved the problem have noticed that the GPU idles at around 157 clock in 2D environment and the fix seems to be to set idle at higher clock. However, I noticed that all threads I have read are for problems where people aren't necessarily overclocking. And also, I observe ATI overdrive and GPU-Z that my card idles at 400 anyway (which is where people recommend setting min. idle).
I don't want to give up my overclock and I want my GPU to be stable in 2D as this is the last problem (fingers crossed) for a stable system that I can then forget about.
Can anyone help me out please ?? Much appreciated in advance.
