Need Help! again...
http://www.tomshardware.com/forum/285368-28-problem-help
guess what, my bad day is not done yet... i attached 2 more fans, and the sound card... :(
and now the screen is blank after windows loading screen...
undoing it seems do not work.. :S
1 answer Last reply
More about need help again
  1. If you want to see if your cpu heatsink is properly installed, turn the board over and check the plastic pins and see if they are all evenly seated. If not, try reinstalling the heatsink. You may have a heat issue as the previous posters suggested. Also check your video cable connections at each end to see if one is loose.
Sound Cards Components
