Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] GTS 250 SLI Power Supply
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] GTS 250 SLI Power Supply
Best answer from ct1615.
Hi all,
I currently have a pair of GTS 250 in SLI running off of a OCZ ModXStream Pro 600w Power Supply, but I'm having a lot of problems. Is this power supply enough to run SLI?
If not, I'm thinking of getting this power supply since it's on sale right now: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341003 Is this one alright? Thanks a lot in advance.
Reply to berkeleyboi
ocz psus are mediocre at best. get a corsair. maybe a 650
Reply to shovenose
I contacted BFG tech support about this and they sent me this in response:
"As far as the power supply
goes, one GT250 requires a minimum of 475 watts and as a general rule in an SLI
setup you should assume 1 + 1/2 for both cards in SLI. That would put you at a
minimum requirement of roughly 712 watts, well outside of your 600 watt power
supply."
Any truth in this statement?
For a pair of GTS 250 in SLI, the 600W PSU is marginal. For a system with a single GTS 250 the recommended PSU is 450 Watts minimum.
Therefore, you may be better off with the 850 Watts PSU that you selected.
In my system, I have a GTX-275 as well as a GTS-250 (PhysX) and I am using a HX 850 (850 Watts) Corsair PSU.
Reply to Ubrales
supply."
They're out of thier minds.
http://www.tomshardware.com/review [...] 72-10.html
Reply to delluser1
"OCZ ModXStream Pro 600 W proved to be an outstanding mainstream 600 W power supply, surprising us at all and every level."
http://www.hardwaresecrets.com/art [...] view/936/9
------------------------------ defeating idiot fan boys since 2008.
Reply to ct1615
Hmm... it seems like I'm getting contradicting answers here. Is my power supply alright or do I need a new one? If I get a new one, how many watts do I need and what brand should I get?
Best answer
sometimes im shocked that anyone would ever come here seeking help by some of the answers i read.....
Reply to ct1615
Whether your PSU is enough or not depends on the rest of your hardware.
Use http://extreme.outervision.com/psucalculator.jsp and look if it suffices.
But all in all i think your ModXStream 600W is enough for your two GTS250.
Reply to gz3ro
Based on the calculator, it seems like I have enough power. And I have run OCCT power supply test for 2 hours without problem. I'm starting to think the BSOD isn't because of the power supply since I'm getting the BSOD even with just a single video card.
are both cards giving you the BSOD as you run them individually or just a specific single one?
Reply to ct1615
I am currently testing my memory again with memtest. Afterwards, I will check the other video card by itself to see if it BSODs on me.
And although I might not need a new PSU, the 850w one has really good reviews from some sites:
http://www.overclock3d.net/reviews [...] _atx_psu/7
And since it's on sale for another couple hours, should I just go ahead and grab this thing for 50 bucks?
There are 2017 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 7 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
