Hey,
So first off, I have some hardware experience (replacing RAM, HDD's, CD drives and such) But i've never done anything of this scale. So I finally broke down and bought all the parts I need for my new comp, here is a list of the build.
Antec 1200 Case.
LG Flatron 23" monitor.
ASUS P6TD Deluxe ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?item=N82E16813131403
Intel i7 960 3.2 GHz
OCZ Gold 6GB (3 x 2GB) http://www.newegg.com/Product/Product.aspx?item=N82E16820227365
OCZ Vertex 2 SSD (50GB) http://www.newegg.com/Product/Product.aspx?item=N82E16820227528
CORSAIR CMPSU-850TX 850W Power Supply http://www.newegg.com/Product/Product.aspx?item=N82E16817139009
SAMSUNG Spinpoint F3 500GB http://www.newegg.com/Product/Product.aspx?item=N82E16822152181
CoolerMaster V8
XFX ATI Radeon HD 5870 1GB Video Card http://www.portatech.com/catalog/viewitem.asp?id=27306&r=p
Last night I finally got the last of the parts, I sit down and start to put it all together, (I am using a static mat with a wrist band and a ground on the case) I put the processor on the motherboard, but the arctic fox thermal past on, put the cooler master on (with the annoying back plating) mouth the MOBO, install the RAM, SSD, HDD, CD drive, Video Card, power supply. Do all the wiring, (SATA to all of the devices, and power to them, power to the MOBO.
So I finally finish the installation, check everything I can think of once, then again. I plug it into a surge protector. Fire up the monitor first, then the power on the power supply. then finally the big test, I hit the power button. The thing comes to life, all the fans start up, and light up (I have lights and fans on the case, the CPU, the graphics cards, they all start up and run)
So i'm waiting and waiting, nothing comes on the screen, I wait about 2 minutes, nothing. Hmmm weird. So I turn it off and check my MOBO book. It has a "before you start" checklist sorta thing, and at the bottom of this list it says that for diffrence symptoms i'll get diffrent BOIS "beeps" (one stead beep then a short one to indicate that it can't detect memory, that sorta thing) Well I didn't get ANY beeps, so I turn it off. plug in some speakers to the back of the MOBO, and fire it up again. Nothing on my monitor, nothing beeping, just silently running all of its fans and lights, not doing anything else.
So end result: Monitor doesn't detect any input from the DVI, I don't have anything on the screen, and the BIOS doesn't come up. I would say "oh thats probably a Video card" But I don't hear any beeps and it doesn't seem like the think is thinking at all. I dunno.
Like I said, HELP!
Thanks!
Dave.
Antec 1200 Case.
CoolerMaster V8
Like I said, HELP!
Thanks!
Dave.
