I'm putting together a new build with a i5 680 and a gigabyte h55m-usb3 mobo. It's been awhile since I've bought ram but these two seem good for the money. I'm looking for a quality product with good support. Not planning to oc right away but may do some light stuff later.
G.skill 1600 mhz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
G.skill 1333 MHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
Or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231275
What do you guys think would work best(if you have other recomendations I'd love to here them)? Would there be a great advantage of going with the 1600 ram? The motherboard also says the dimms are 1.5v so could I even use ram that is spec'd at 1.65?
I was also eyeing these mushkins but they don't seem as nice for the money.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226101
G.skill 1600 mhz
G.skill 1333 MHz
Or
