G
Guest
Guest
I have two 4 GB DDR3 ECC RDIMMs that I'm trying to install on a Dell Poweredge T310 with Xeon X3440 processor. A pair of 1 GB ECC RDIMMs are currently installed and working fine. However, on installing the 4 GB DIMMs the T310 shows a "System Board failure" with Error code (the 4 LEDs) 1 and 4 and a flashing amber light.
The system won't power up beyond the fans and the LEDs coming on so there's no chance of running any diagnostic tests.
On re-installing the 1 GB DIMMs the system works as per normal.
Has anybody else experienced this problem and any suggestions?
Thanks.
Thanks.
