Will my power supply do the job
Hi,
I am new to the forum.
I am building a new rig:
CoolMaster HAF 932 case
Asus P6X58D Premium
Intel i7 960 or 975 cpu
Prolima Tech Megahalems cpu cooler
ddr3 1333 or 1600 6 to 12 GB memory
Radeon 5870 video card
Asus Xonar Essence STX audio card
two internal optical drives
350 + 750 SATA-3 hdd
Dell U2711 or NEC equivalent monitor
I have 2 questions. 1. will my PC Power and Cooling Silencer 750(red) power supply be able to do the job +? 2. If i replace the 240mm side fan in the case with 3 or 4 120mm will the noise increase be noticeable to the average person? I do not have super sensitive hearing.
BTW outstanding advice and guidance on the Tom's Hardware forums.
Thanks and BE WELL,
newmoon
8 answers Last reply
More about will power supply
  1. If they are good quality fans then you may not notice the difference, but in general larger is more quiet.
    A 750 PSU should deal with anything less than XFire.
    I am assuming cost is not a big issue so I guess it doesn't matter, but what are you doing to need 8-12 gig of RAM?
    A lot of formula development and calculations while i watch videos, play games, etc.
    Been blessed with some unexpected cash and choose to use my portion on a new rig.
  3. A lot of formula development and calculations while i watch videos, play games, etc.
  4. A good 550 watt PSU, such as a Corsair 550VX (41 amp 12 volt rail):
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
    will run your system.
    So, certainly, a good 750 will.
  5. why an i7 975?
  6. Somebody_007 said:
    why an i7 975?
    basically to somewhat future proof the system. Could just as easily go with a 930 or 960 and save the bucks.
  7. Ithought the i7 980 was around the same price and much faster is that right?
  8. @OP:
    1. That PCP&C 750w will do based on your setup.
    2. Why change the fan anyway? Of course, 4 120mm would create more noise than a single 240mm running on low.
    3. I think 6gb is already plenty of RAM. No need to go beyond that for now. I suggest you spend your money on a good SSD instead which would make a whole lot of difference in your system.
New Build Power Supplies Systems Product
