Hey. I recently ordered my computer and I'm having what seems to be display driver issues. The card I'm running with is a HD5970. I ordered it because I wanted longevity in the computer market, but I was unaware of what seems to be an abundance of driver issues. Ever since I've been using the computer (March 2nd) it's been locking up at random times while in game (World of Wacraft). It's displayed different symptoms at times, from my screen freezing and taking on a strange green hue to the monitor losing a video signal entirely. I am running with Windows 7 and after the most recent time I went digging into my solution center logs and noticed a string of video driver malfunctions dating back to day one. The lock ups are annoying, but they aren't my main concern. Last time it locked up I felt the PCi slot on the back and it was very hot to the touch. I'm not computer savvy, but it seemed extraordinarily hot. I have a temp/fan gauge monitor but it doesnt have a sensor for my card, it only monitors the fan speed of the PCi slot. Now the confusing part is that the fan was displaying @ a 4% run speed while the card was exceptionally hot. This tells me that the fan isn't running like it should be.
That aside, I went ahead and tried to install the latest drivers myself. I went to ATI, ran the update software, but when I went to install my computer screen would go blank about midway through installation. So I've been unable to successfully install the new drivers. I don't believe the card has been damaged at all since I've yet to recieve any critical errors beyond driver malfunctions. The lock ups also are not consistent. They'll range from happening during periods of time while I am idle or afk to when a surplus amount of animations are happening at once. To this day I can still run World of Warcraft at Ultra ingame settings just fine until a random lockup decides to rear it's ugly head, my only concern is that I'm unknowingly burning up my card. It should also be known that the issue has not shown itself in any other instance beyond gaming.
System specs are:
i7-920 @ 2.66
HD5970
9Gigs @ 1333
875w PSU
300Gig 10k RPM HDD
Btw, the current driver version I'm running is 8.712.0.0 dated 3/2/2010. On a side note I was wondering how you install drivers on a dual gpu card? It lists the 2 gpus seperately in the hardware listing . Does updating the driver on one update the other as well?
Thanks in advance!
System specs are:
i7-920 @ 2.66
HD5970
9Gigs @ 1333
875w PSU
300Gig 10k RPM HDD
Thanks in advance!
