Are these parts compatible?
3 answers Last reply
More about parts compatible
  1. Yes but a few things:
    - get an AMD Phenom X4 II 955 instead. The higher number means nothing and both are clockable to 3.8-4.0 easily on air.
    -How about this instead, 890, usb3, sata iii,
    ASUS M4A89GTD PRO/USB3 AM3 AMD 890GX HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131631&cm_re=asus_am3_890-_-13-131-631-_-Product
    -These g.skill ripjaws are better and not that much more money. Although newegg is oos right now perhaps you can find it on tiger direct or zipzoomfly.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303&cm_re=g.skill_ripjaws_ddr3_1600-_-20-231-303-_-Product
    -Samsung spinpoint f3 1tb, this is a no brainer. Either that or 7200.12
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&Tpk=samsung%20f3%201tb
    (they they have lower capacities)
    - Kind of an unusual case but if you like it then go for it. Might I recommend the Haf922?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=haf_922-_-11-119-197-_-Product
    - For like $30 more then those 5770s you can get a single 5870. http://www.newegg.com/Product/Product.aspx?Item=N82E16814125316&cm_re=5870-_-14-125-316-_-Product
    - I bought one of these Cooler Master 120mm fans. It pushes a slight bit more air then your selection and it's quieter.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103061&cm_re=cooler_master_120mm-_-35-103-061-_-Product
  2. Also no AM3 build is complete without one of these
    Cooler Master Hyper 212 Plus - $30
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=cooler%20master%20hyper%20212%20plus
  3. Thanks, I subbed in everything you listed except the RAM (that Mobo has some BEAST features), I would have to O.C. it the BIOS and it had a lot of bad reviews when being used on an AMD build, but the 1333 is good enough for me. But one question, the MoBo can support 6GB/s HDD, so shouldn't I take advantage of that and spend $10 more on the one below than the one you listed, or is there some sorta fault with 6GB/s drives?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
New Build Computer Compatibility Systems Product
