i built a system with
Core i7-930 cpu,
Gigabyte GA-X58A-UD5 Mobo ,
WD Caviar Black 1TB 7200 RPM SATA 6.0Gb/s HD ,
WD VelociRaptor 300GB 10K RPM SATA 3.0Gb/s HD ,
Corsair HX 850W Mod PSU ,
Cooler Master HAF 922M Case,
2x nvidia quadro nvs 420's and
Corsair Dominator 6GB DDR3-1600 (PC-12800) CL8 Memory.
I was running at 32 to 37deg C when i first built it at home, but now in my office a few weeks later and since the weather really started to warm up im running at 45 to 48deg C . I dont know if this is just due being at the new location or if i have a cooling issue. The CPU has a recommended temp of 37deg C i believe which i was originally running well under. Im using Gigabytes Easy Tune6 smart fan control with the auto setting. I dont know if i should add another fan or play with fan settings manually. The case has 3 fans and i installed my PSU with its fan facing down. Anyone have any advice or input??
Core i7-930 cpu,
