Home build for Arch/Viz Workstation Advice Sought
APPROXIMATE PURCHASE DATE: by August 2010
BUDGET RANGE: 1500-1700
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Microstation/Luxology, 3dsMax, Rhino, AutoCad, Adobe CS 3 (primarily Illustrator) are the most common components of my workflow.
PARTS NOT REQUIRED: Mouse, Keyboard, Monitor, Power cords and the like.
PREFERRED WEBSITE(S) FOR PARTS: newegg
PARTS PREFERENCES: brand slut-don't particularly care, as long as it's of good quality.
OVERCLOCKING: No
SLI OR CROSSFIRE: Yes, in the future.
MONITOR RESOLUTION: Would like to run two monitors at a high resolution
ADDITIONAL COMMENTS: Trying to build a system for doing Arch/Viz type work. I'm a student, but also do some freelance work. In any case reliability and performance on a budget is what I'm going for. Although I'm only planning on running one quad core processor at the moment, I plan on adding another later, as well as possibly running a couple of quadros in sli (if that's even possible/desirable). Intend to run XP Pro/65 or Windows 7/Pro as an OS.
Any comments on fatal flaws in this combo of parts, ways to increase performance at this price point, or ways to achieve similar performance at a lower price point are all welcomed.
Thanks,
Tim Patterson
A preliminary build:
Intel Xeon E5420 Harpertown 2.5GHz LGA 771 80W Quad-Core Processor Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117147
SUPERMICRO MBD-X7DAL-E-O Dual LGA 771 Intel 5000X ATX Dual Intel Xeon Server Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182101
PNY VCQFX1800-PCIE-PB Quadro FX 1800 768MB 192-bit GDDR3 PCI Express 2.0 x16 Workstation Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133272
COOLER MASTER Silent Pro 600 RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171036
Crucial 8GB (2 x 4GB) 240-Pin DDR2 FB-DIMM ECC Fully Buffered DDR2 667 (PC2 5300) Dual Channel Kit Server Memory Model CT2KIT51272AF667
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148128
(x2) Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
5 answers Last reply
More about home build arch workstation advice sought
  1. Should have said XP Pro/64, Windows 7/64 for Operating Systems.
  2. > BUDGET RANGE: 1500-1700
    Before you decide, check out the newest motherboards with AMD's 890FX chipsets
    + Thuban 6-core AMD CPU.
    http://techreport.com/articles.x/18799
    Also, go for a full 16GB of RAM, and look into
    RamDisk Plus from www.superspeed.com :
    http://www.superspeed.com/desktop/ramdisk.php
    We wrote a review about it here, finishing up with
    a 16GB Intel Q9550 in an ASUS P5Q Premium:
    http://www.supremelaw.org/systems/superspeed/RamDiskPlus.Review.htm
    The Intel Xeon E5420 is pretty far down in this list:
    http://www.cpubenchmark.net/cpu_lookup.php?cpu=[Dual+CPU]+Intel+Xeon+E5420+%40+2.50GHz
    The LGA-771 socket is now 4 years old:
    http://en.wikipedia.org/wiki/LGA_771
    http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors
    I predict that 4 x DIMM slots will see quad-channel access
    in the foreseeable future, putting an even larger premium
    on Intel's LGA-1366 Nehalem variants.
    MRFS
  3. e.g.:
    Gigabyte GA-890FXA-UD7 AMD 890FX Motherboard
    http://www.pcstats.com/articleview.cfm?articleID=2514
    GIGABYTE GA-890FXA-UD5 AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128441&Tpk=N82E16813128441
    AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103849&Tpk=N82E16819103849
    AMD Phenom II X6 1055T Thuban 2.8GHz 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851&Tpk=N82E16819103851
    MRFS
  4. Thanks for the detailed information, MRFS. I put together a build on New Egg using your suggestions, and it definitely seems like I'm getting better performance for almost exactly the same price.
    I appreciate it!
  5. Ditch the WD drives for Samsung Spinpoint f3's. They are cheaper and faster.
New Build Systems Product
