Okay thanks again. Now I am trying to decide between the haf 932 and the haf922. I want to get the haf 922 because i am going to add 4 122mm fans on the side each giving out 105 CFM. what do you guys think i should do?
I would go with the HAF 922 for a case. It is a very nice case and at a great price on Newegg.com
Unless you have a cpu which supports triple channel memory, you want 2 sticks of memory. Other than the i7's all consumer cpu's are dual channel. This means that the cpu can access 1 pair of ram sticks at a time, and switching the active pair takes time.
Anyway, more than 4GB of ram isn't going to boost your performance.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226116 would this ram work with a 955 BE
That is still triple channel memory, find some dual channel. The 955 doesn't support triple channel. Heres the Memory you were looking at, at first just in dual, http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193 It would work for your system great!
Can you double check manual. Really DDR3 2000(O.C.)/1333/1066? not 1600?
Either way here's a good 1600 ddr3 set, cas7
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303&cm_re=g.skill_ddr3_1600_ripjaws-_-20-231-303-_-Product
Overclocking in the sense that you just bump up the dram clock multiplier. Hardly an overclock in my book but I assume your mobo should be able to do 1600 if it can do 2000. Perhaps 2000 is a misprint and it should have read "1600(0.c.)/1333/1066"
Go 2x2 gb or go 4x2 gb / 2x4 gb. 6 gb only makes sense if you can find 3gb sticks (which would be like finding a 3 dollar bill methinks) or you are going triple channel.
Yes, even I actually found that quite rude considering that other people here are helping you.
You could have rephrased that to something more polite : "Thanks for your reply, nut which case do you think is much better?" or something similar to that.
