SSD SYSTEM Problem
MGPowers
6
Hello, Recently I purchased my first SSD drive (Intel 520 120g) I have tried numerous times to solve a rather simple problem...or so I thought! I have tried both a fresh new Install and a Clone Install but no matter what I do, the system hangs after the Bios prompt to a Black screen with a Blinking curser. The system will boot fine when the Windows 7 install disc is loaded. Also I have no problem with my HD Drive. I really thought this transfer from HD to SSD was supposed to go easy.....fool me!
OS Name Microsoft Windows 7 Enterprise
System Manufacturer INTEL_
System Model DX48BT2_
System Type x64-based PC
Processor - Intel Core2 Quad Q9450 @2.66GHz, 2666 Mhz, 4 Core(s), 4 Logical
Graphic Evga GTX 560 Ti 2048mb
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 8.00 GB
MGPowers
6
Ok new Details.. I have tried this several times now and even with a clean install of Windows it won't boot without the disc either! It has to be a MB setting right?
It says Intel SSDSC2CW120AS ATA Device Shouldn't that be sata device?
As of now I have everything working. Except the Disc problem.
MGPowers
6
I have tried the repair solution and the bios boot order....that was the first thing I did. I didn't change any other sttings in the Bios....that is what I am unsure of!!!
Let us back up a little bit.
1) When you did the repair solution, what did the system report show?
2) Do you have more one SSD/HD in your PC?
3) How did you do the install? Did you set the AHCI in the bios and disconnect the HD before installing wind 7 to the SSD?
4) Do you try to other SATA port?
