Okay so I bought an Asus DRW 24-B1ST CD/DVD Burner from newegg and it arrived today via UPS. I threw in the drive, connected it properly and got it running right off the bat with no problems. Then I tried updating the firmware and ran into my first issue. Every time I go to update it I get an error message that reads:
'No matched drive detected ! This utility is only for ASUS DRW-24B1ST drive. Detected drives: 0-1-0-0 D:ASUS DRW-24B1ST C 1.05'
After multiple forum and Google searches I came across several ways to resolve the issue, but had no luck. Some of the solutions I tried were the fixit solution and the regedit solution. Fixit did nothing and when I tried the regedit solution, I couldn't find the upper or lower filters anywhere in the specified area. I gave up on the firmware since I burnt a data disk (American Dad - Season 6) prior to any of this B.S.
The issue I'm having is burning .iso files. The main reason I bought this drive was to burn the .iso files I had to a disk (i.e. Ubuntu) so I wouldn't have to use my room mates laptop to do so. I've used at least 10 different programs, all dedicated to burning iso files and all I get after the burns are complete are coasters. I've thrown at least 12 dvd-r discs away already. I read somewhere about lowering the write speed, but still the same results.
At this point I have no idea what's going on and I've given up all hopes for this new drive seeing as it can't do the main thing I bought it for. It reads, it writes data but cannot burn an iso?
Any help would be greatly appreciated seeing as how all my attempts have failed. If it makes any difference, I'm running windows 7 64 bit
