Hi people!
I'm having a very strange problem with my RAM.
A few days ago my computer crashed and after resetting it it couldn't boot windows. I tried to recover the system from a backup image and there a blue screen appeared with the notice "memory problem".
Technical info of my computer: CPU Intel Core 2 Duo E6850, MB Gigabyte GA-P35-DS4 (rev.2.1), 4GB Ram (4x1GB) corsair CM2X1024-6400C5DHX, Video card ASUS EAH5850, PSU OCZ 700W, 500 GB HDD SATA, and nothing more interesting
So I decided to remove 2 RAM modules of the four I had installed. There I could restore my system without any problems after which I did a fresh install. Afterwards I decided to to a memtest of all the modules and these are my results:
With the first two there was no problem.
I've then added the remaining two RAM and at the end of the third phase an error occured and memtest crashed
I thought that the other 2 RAM were faulty so I tested them separately. By each test errors occured.
However, I removed the 'faulty RAMs' and installed the working ones. As I tried to boot the computer, it didn't get to the POST or Bios.
Now I'm testing one of the 'working RAMs' separately but I'm dismissing the idea that a module must be broken.
Could it be a problem with the motherboard?
Ah, by each test I left memtest run three times, to be sure that the RAM actually works.
And another thing, I know from corsair's wbesite and from Gigabyte that my modules are not tested to work as I've installed them on my system, i.e. 4x1GB. They recommend to have either 2x1GB or 2x2GB. However my computer worked just fine for a couple of months with the 4GB RAM. Befor I had the 2GB of corsair till I decided to expand them to 4GB.
Does anyone has a clue what could the problem be? I'm now trying to test each RAM slot of the motherboard.
Thank you all and I'm sorry for my primitive english!!!
