Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] Can you use an ATX 12v 4-pin power connector on a 8-pin port?
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] Can you use an ATX 12v 4-pin power connector on a 8-pin port?
Best answer from jsc.
Hello, I have a ATX power supply that does not have a 8-pin power connector. but the motherboard i have( XFX nForce 780i SLI) uses a 8-pin plug in. Can i use the 4-pin connector on it for half of it and be ok?
Reply to LoneStar45
Depends on your board, check the manual and see if it will work with only a 4 pin, many that will have a flip up cap over the other 4 pins in the connector.
What power supply do you have?
Reply to hunter315
The manual says nothing about 4 pin
Reply to LoneStar45
Interesting, you can try it, it wont hurt anything if it cant run with it, it just wont boot up properly or might behave strangely under heavy load if it does need the 8 pin connector
Message edited by hunter315 on 07-11-2010 at 06:08:04 AM
Reply to hunter315
The correct answer is no, it is not required. However, most modern power supplies have 8 pins so my question would be is the PSU good enough for your system?
Reply to FALC0N
Best answer
The Intel Gigabyte manuals say that a 4 pin plug is sufficient for CPU's up to 120 watts. So for anything other than an EE chip, you should be OK.
(A Q6600 OC'd to 3.6 GHz with vcore set to 1.42 volts pulls 9.5 amps or 114 watts.)
Reply to jsc
I have seen 200 watts pulled off a 4 pin. So you can do a lot with a 4 pin if need be.
But I want to reiterate that the psu is of concern to me. There are lots of good PSU's with a 4 pin but most 4 pin psu are not so good. I am very interested to hear the OP's PSU model.
Reply to FALC0N
So can I put an Intel Pentium Dual-Core on My Mobo?
Reply to LoneStar45
You can put anything on your motherboard. That 120 watt thing is a recommendation, not a requirement.
Reply to FALC0N
There are 1990 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 7 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
