Does drive wear if unmounted but still plugged in to power
tbcatch22
Does a sata drive, or any drive for that matter, wear if unmounted - or - can I increase the drive longevity if I unmounted it, but still have it plugged in to power?
Details...
Running kubuntu 12.04. I have a sata drive, not a raid, used solely for backups. This is an internal drive.
I want to increase the longevity of this drive as much as possible. Does it increase the drive longevity / decrease the wear and tear on the drive if the drive is only mounted when A backup is performed?
If the drive isn't being used, IE: reading/writing anything, it will shut off and not move. This will dramatically increase the life span of the drive.
tbcatch22
Thanks.
So - is sounds like I can leave the drive mounted. If its not doing being written to, such as during a backup operation, then there is little wear and tear on the device to be concerned about, correct?
(to clarify: when I say "unmount the drive", i mean issuing the umount command. Not physically removing the drive from the computer)
