Recently bought and assembled a new system and for the first day it posted with no problems. Initially I couldn't get the lan card to work right. Turns out my cable was lying - said it was a cat5e but really was just a cat5 which doesnt work with my mobo's "fast ethernet" port. That was after a day of unistalling and reinstalling windows 7 and all the drivers.
After that it still posted fine, then i couldnt get BF: Bad Company 2 to run without BSOD on start up. One fix I saw said Catalyst Control Center was the problem. So I uninstalled it and installed only the driver for the video card. Now I get an odd beep code when posting.
Here is a recording of the beep code
I can't quite figure out. Sounds like a two really short beeps together then another two really short beeps, then a final beep. My best initial guess was 1 long and 2 short because it posts and boots. Which would mean thats either bad memory or a possible video card problem.
CPU: i5-2500K
Mobo: MSI P67A-C45
RAM: OCZ OCZ Reaper HPC Edition 2x2Gb
GPU: HD 6870
Haven't overclocked it yet.
Bad Company 2 now works and no BSOD. Guild Wars works. And Starcraft 2 works.
Used the mobo utility tool to test the memory and it passed. Should use another tool and test it more extensively or is it my GPU?
Thanks.
CPU: i5-2500K
Mobo: MSI P67A-C45
GPU: HD 6870
Thanks.
