hi, im getting my new pc, i have some of the parts selected but i have a very big question on some parts, especial de MB and VGA.
this are the component that i pick up:
Intel i7 920
Corsair CMPSU-750HX
Corsair Dominator 3x2gb DDR3 1600
WD Caviar Black 1TB
thats the component that im sure off but i have a big big doubt about the MB and VGA my options are:
Asus Rampage II Extreme
Asus Rampage II Gene
Saphire vapor-x HD5870 1gb
MSI 480GTX
well first the vga, i read that the nvidia is alittle faster than ati special with dx11 and tessellation effects but i also know the heat, noise and power consumption, but i read that nvidia cards are that way and with a good ventilated case can resolve the problem, so i dont decide what buy.
and the mb is other ?? for me i dont know what mb to buy i read that rampage ii gene gets little hot, and with gtx480 i think can get hot hot, i realy dont know much info on mb.
So if you ppl can help me, and tellme what is the best i can get for that range of price, or tellme if you recomend another item that i have chose i will realy thanks.
*sry for my english lol
Intel i7 920
Corsair CMPSU-750HX
WD Caviar Black 1TB
MSI 480GTX
