Hello all,
I'm putting together a system for a friend of mine that will be used exclusively for multitrack audio recording/mixing/mastering etc. His budget is about $500, sans peripherals, which he has taken care of. He'll be using a Presonus Firepod audio interface, so the motherboard must supply the necessary firewire port(s). I opted for a small system/applications hard drive, and a larger storage drive for audio files, with the assumption that he'll get much better multitrack ability with separate system/storage drives due to the high amount of data that needs to be written during recording. I went MicroATX just for the sake of saving space in his cramped studio, plus the case was on sale. Here's what I came up with so far; any advice would be appreciated. Thanks in advance! I'll be ordering from newegg, where possible, fyi.
Rosewill R101-P-BK 120mm Fan MicroATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147112 $24.99
AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 95W Quad-Core Desktop Processor Model HDX945WFGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103809 $149.00
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030 $26.99
Western Digital Caviar Blue WD3200AAJS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136098 $47.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277 $109.99 (these were on sale, but no longer)
GIGABYTE GA-785GMT-USB3 AM3 AMD 785G USB 3.0 HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128432 $74.99
Western Digital Caviar Blue WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075 $39.49
Antec EarthWatts Green EA-380D Green 380W Continuous power ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033 $44.99
Total, with shipping: $545.00 (when i copied these the other day, some sales may have expired)
