Power Supply & Case For 8 HDDs FreeNAS Server
Last response: in Components
July 12, 2010 4:35:48 PM
It's been a very, very long time since i built a PC/Server, and so i'm very much out of touch on the current/new technologies.
Basically, i need a case and power supply, to support a 8x 2TB HDD FreeNAS "server", and while i would love to have the fanciest case/power supply, i really need it to be functional, meaning, no unnecessary things.
Any recommendations?
a b ) Power supply
July 12, 2010 4:58:03 PM
Hi newcomer and welcome to the Tom's hardware forum.
What other specifications the rig has? mobo, cpu, gpu, network card...with that we can give u a better advice.
m
l
July 12, 2010 5:09:21 PM
I have not defined the mobo/cpu, but it would be no very powerful, as it is not required by FreeNAS.
Maybe an Athlon/Sempron, or something like that. GPU on board.
So far the case i like the most, that is more or less affordable (in my country at least), is the Thermaltake Atx Element S Vk60001n2z (u$s 130).
m
l
a b ) Power supply
July 12, 2010 8:20:10 PM
Ok.
I think that with a good 350W or 400W from a good manufacturer is enough.
m
l
July 12, 2010 8:33:03 PM
So maybe 500 w to be sure? how can i be certain?
m
l
a b ) Power supply
July 12, 2010 8:49:07 PM
Yeah if u want be sure 500W is enough for the rig. The HD usually don't use much power but like I think that u plan use the rig 7x24 is better go with a PSU that support that work.
m
l
July 13, 2010 12:10:51 AM
Great, so any budget (as in no fancy sh*t) recommendations?
m
l
a b ) Power supply
July 13, 2010 6:07:55 PM
Do u have a special site for buy? Like newegg or tigerdirect?
m
l
a b ) Power supply
July 13, 2010 7:47:29 PM
Really funny.
Thermaltake Purepower 550W is a very good option for u since the rest of the list aren't very good.
Saludos desde Colombia... :lol:
m
l
July 13, 2010 7:58:46 PM
I see. The only problem it that it has support for only 4 SATAS? Can i use an Y splitter?
Also, there is Thermaltake Tr2 500w for 7 dollars less, is it worth it?
PS: estuve en colombia hace 15 dias, en Bogota, donde tengo familia ... fuimos a tierra caliente y todo ;)
m
l
a b ) Power supply
July 13, 2010 8:07:22 PM
The TR2 isn't a very solid PSU that's why recommend the Purepower. Try to find a molex to sata converter (like this that's a better option.
m
l
