Dell inspiron 6000 power supply problems
Hello,the battery light (usually green) has started flashing orange even when the battery cord is plugged in. I assume I will run out of power unless something is fixed.
1 answer Last reply
More about dell inspiron 6000 power supply problems
  1. According to the manual they say that the battery might be dead. The way to tell is to remove the battery and run it on the power plug in.
Power Supplies Battery Dell Inspiron Components
