You totally solved my problem for me. I'm using the HX750W externally as a second power supply to power the video card.
The position of the PCI slots in the machine is such that the video card and the empty slot openings are down near the floor. I ordered two 12" PCI-Express power extension cables from NewEgg that will result in a few inches of cable sticking out of the back of the machine for easy connection/disconnecting.
And if I had any questions about turning on the power for the HX750W with the creative control of the 24-pin plug, well, Corsair made that really simple for me with an item on their website. See this item from their "tips" page for power supplies that come up when beginning to submit a support ticket (which tells me which pins to jump
and that it's totally safe):
Q: How can I test my power supply?
A: You can easily test a power supply for functionality with a simple paperclip. First, disconnect all the cables from your motherboard and other devices, but leave the power supply plugged into the wall. Next, bend the paperclip until you have a U shape. Find the 24-pin ATX connector and plug one part of the paperclip into the socket where the green wire ends, and the other end into the socket where a black wire ends. Make sure the power switch on the back of the PSU is on, (should be the I symbol) and the fan should spin up. If it doesn’t, your power supply may be bad.
(Note that I spoke to ThermalTake. They no longer make a 450W internal power supply. Only a 650W, and it takes up two bays. I need all my drive bays for what I want to do. It also has an adapter to turn on power that goes in-line with the 24-pin system board power cable, and I don't know how HP has modified the pin-out, so these are two more reasons to go with the external solution instead. But it was a good idea.)
Thanks so much! You saved me from having to build a whole new machine!
Now, having said all that, I still would like to take you up on your offer to help me determine if the existing power supply in the machine is enough. I learned today that your asking about “amps” is right on the money and that everyone else asking about wattage was missing the point. Check out this other item on the Corsair “tips” page for power supplies:
Q: My new video card says it needs a XXXX Watt PSU, is this going to be good enough?
A: Ignore wattage for a minute and find out the Amps that your video card requires on the +12V rails. Match that number against our power supply, and you will more than likely find that the Corsair HX series provides more than enough power.
So, here’s a picture of the label on the power supply that came in the machine (I don’t’ know how to translate to answer your question and I can’t find anything online, so this image is the best I can do, which I threw up on my website):
http://www.silver100.com/x/z400powerlabel.png
The hardware that’s in the machine is:
• Intel Xeon W3520 2.66GHz/8M Cache Processor
• RAM 8GB DDR3 1333
• 5 hard drives: Samsung SpinPoint F3 1TB
• DVDRW(Light Scribe)
• I can’t really elaborate on the cooling fans, other than there are one for the CPU and one for the case.
• And of course the nVidia GTX-470, which I assume you can find the actual "amperage" requirement on a lot faster and more reliably than I can (but I'll look when I get back to the office later if you need me to).
Thanks so much!!!
Jay
