So I am looking into building my second computer and have decided on some of these parts. the computer will be used for rendering, autoCAD, Revit, Sketchup, Photoshop, lots of file conversions and such... Also gaming of course.
I will be attempting to OC the i7 to 4GHz
Let me know what you think.
Case: CM Storm Sniper Bought for $109 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119194&cm_re=storm_sniper-_-11-119-194-_-Product
CPU: Intel i7 930 Bought for $199 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
Noctura NH-D14 http://www.amazon.com/gp/product/B002VKVZ1A/ref=s9_simh_gw_p23_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1G5ANBDKYMA0SMRCZXTC&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
Ram: G-skill 1600 (3) 2gig http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
GPU: Want the Sapphire Vapor 5850 but can't find it in stock or its too much when found. Also looking at Asus eah5850 TOP which is $311 at TD with bing. http://www.newegg.com/Product/Product.aspx?Item=N82E16814121375&cm_re=asus_eah5850-_-14-121-375-_-Product
HDD: 750gig WD black sata ( want to get 2 for RAID 0 at a future point)
Mobo: Cant decide between the gigabyte x58a-ud3r, p6x58d-e, or p6x58d premium.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423&cm_re=gigabyte_motherboard-_-13-128-423-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614&Tpk=p6x58d
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
I have read alot of reviews and it seems the ud3r has some issues with buzzing or some kind of noise. The p6x58d-e is nice but cant find a whole lot of info. The premium just seems like it might be overkill. But between the 3 is only a $63 difference (with bing)
PSU: I have decided on Corsair but cant decide if I should get a 650 or 750. What do you guys think. I might crossfire in the future when he cards come down in price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Dvd burner
Windows 7 OEM for $100
My budget is around 1300 and I am coming right in that area.
Please help me choose on these components.
Thanks for the help,
Michael
Dvd burner
Michael
