jerry6 Distinguished Jan 21, 2009 896 1 19,115 Jan 21, 2011 #1 Or is it like the old 939 boards where if you ran all 4 slots it will downgrade the ram .
Solution sadams04 Jan 21, 2011 Doesn't appear you can OC above 1866 using all four slots. At 1600 you should be fine with 4 x 4GB...
sadams04 Splendid Nov 23, 2010 4,711 1 26,960 Jan 21, 2011 #2 You should be fine for 16GB @ 1600. Your problems would come in above 1866... "To reach DDR3 1866MHz or above, you must install two memory modules and install them in the DDR3_3 and DDR3_4 memory sockets" Upvote 0 Downvote
jerry6 Distinguished Jan 21, 2009 896 1 19,115 Jan 21, 2011 #3 I thought the rev 2.1 board could run @ 2000 . I just want to put in another 8 Gb fill up the slots , I use Gskill F-3 1280 cl9 , 1600 is enough , just want to be sure it works before I buy So 1866 will not work on 4 slots ? Upvote 0 Downvote
sadams04 Splendid Nov 23, 2010 4,711 1 26,960 Jan 21, 2011 Solution #4 Doesn't appear you can OC above 1866 using all four slots. At 1600 you should be fine with 4 x 4GB... Upvote 0 Downvote Solution
jerry6 Distinguished Jan 21, 2009 896 1 19,115 Jan 21, 2011 #5 Best answer selected by jerry6. Upvote 0 Downvote
