hello all, here are my copy and pasted answers, with details after...
APPROXIMATE PURCHASE DATE: 5/10/10
BUDGET RANGE: 900 but would like to keep it around 700...
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: audio production, that's it.
PARTS NOT REQUIRED: keyboard, mouse, monitors, soundcard
PREFERRED WEBSITE(S) FOR PARTS: newegg
COUNTRY OF ORIGIN: u.s.
PARTS PREFERENCES: intel, but will go with AMD too
OVERCLOCKING: no
SLI OR CROSSFIRE: no
MONITOR RESOLUTION: 1024X768
ADDITIONAL COMMENTS: stable and 24/7 work horse..
up to this point i've settled on an i5. but after reading one of the stickies of this forum, and many posts...perhaps i may go with AMD...i am hoping this forum can provide some direction...
so first... here is my build:
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128412
HD (x2): http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
FAN & HS: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
CASE: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148150
CD: http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127475
so this build comes out to around 800$... im curious to know if there are some parts i could replace to lower the cost? i just need stability and decent processing power for audio editing. not so much recording, but some.
also, can anyone guide me on a comprable AMD build ? would that be cheaper? is AMD for audio tasks a good idea? any help and insight is really appreciated. thank you.
OVERCLOCKING: no
