Hello,i bought an Ati Radeon HD 4650 recently,heres my specs
PSU 300Watt
Intel E2220 Dual core 2.40GHZ (no oc)
8500GT ( oc )
320GB hard drive
2GB ram
the problem is that when i pluged the radeon,my pc wouldnt start,no bios no nothing,but the fans were going etc,i removed the graphic card and now my pc dosnt boot also(was scared to death i tought i fried everything up)but a friend told me to remove one stick of ram to test,then i did and the pc ran ( with no HD 4650) then i pluged second stick and now it works also 2GB ram everything works,then i plugged my HD 4650 ( this time it gave a beeeeeeeeeeeeeeeeeeeeeeeeeeeeep until i shut the pc off) i remove one stick and let the HD 4650 and the pc run with the 4650 and it show up in device manager etc,what is the problem?My friend have a 250W Psu and he run it fine ! ( same graphic card ),i bought this card because it use little power,ppl ran this card on 300W and 250 W,and in psu calculator i see my system with HD 4650 and everything needs only 200W in power,i really need help,what's wrong?
PSU 300Watt
8500GT ( oc )
320GB hard drive
2GB ram
