Hi!
Q1 - I would like to know if the Corsair H70 will fit on a Asus P8P67 Deluxe motherboard.
Q2 - But most important if it's safe to put both of the ''120mm'' fans in one 3-pin fan connector on
the motherboard - or if it's more safe and simple to put the two fans in separate 3-pin connector?
Thanks in advance
M9A2
Thanks in advance
M9A2
