HP deskjet XP problem
G
Guest
Guest
I cannot load my drivers for my HP deckjet 712c on windows xp and those morons don't have drivers out yet on the site. If you call their tech support it's $25.00 just to be put on the phone with them so they can go screw. I need to find drivers so I can use my damn printer can anyone help?
My signature really sucks.
Toejam31
2,989
Best I can do:
<A HREF="http://www.hp.com/cposupport/printers/support_doc/bpd09005.html" target="_new">http://www.hp.com/cposupport/printers/support_doc/bpd09005.html</A>
Toejam31
<font color=red>My Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new">http://www.anandtech.com/mysystemrig.html?rigid=6847</A>
____________________________________________________
<font color=blue>"Does history record any case in which the majority was right?" ... Robert A. Heinlein</font color=blue>
jiffy
1,951
xp driver's won't be on your HP software, but should all ready be in XP. Find your HP printer in add new hardware, and click next, since you don't have a CD. Good Luck
defrage is child's play-fdisk
G
Guest
Guest
That's the problem the ones that are supposed to be and that hp tells you are already loaded with xp don't work or are not there!!! It detects printer in PnP then when I go through setup process it says invaild data sent.
ycs46241
466
you need to remove all old drivers and software , then unplug printer , shut down , plug printer back in, use add printer wizard but pick show all , fin printer modle and use the xp drivers that came on cd. what modle of printer due you have?
