Okay I'm back again with basically the same problem as the last time I posted. My CPU last time was idling at about 80c and I cleaned the heatsink and cpu with 99% isopropyl alcohol and replaced the thermal paste put the heatsink back on which was a massive pain in the ass mind you and it fixed the issue completely I was idling at about 40c and 50-55c under load but now after a few months it has slowly moved up in idle temp a degree or couple degree's at a time and now its getting too hot for me to be comfortable with it.
I want to know is this the heatsink again? Is it defective? and if the heatsink isn't the issue what else can I do to cool the cpu better? What can I use to clean dust effectively and safely and how long can I run this cpu without risking it failing completely? Thanks in advance.
