Corsair HX850W Enough Power?
:hello: Hey everyone.
So I recently sold my ol' Coolermaster Real-Power M700, and brought a Corsair HX850 Power suuply, The main reason was because the old power supply made alot of noise (Coil Whine) which was extremely annoying.
Anyways I plan to go crossfire very soon and would like to make sure that My Corsair HX850 is enough. So below is my system spec's:
Gigabyte GA EX58-UD5
Core i7 920 @ 4Ghz (4.4Ghz for benching) 1.264V
3 x 1GB OCZ Triple Channel RAM @ 1200 7-7-7-21
Gigabyte HD5850's @ 1000/1200 1.225V X2
2 X 10W Pumps
8 Fans
A fan controller
DVD ROM Drive
Samsung Spinpoint F3 500GB
Corsair Obsidian 800D
Corsair HX850
Please take into consideration the fairly heavy OC's on the two cards and the core i7 920.
So is a Corsair HX850 Enough?
Thanks in advance.
5 answers Last reply
More about corsair hx850w power
  1. Definitely. A 750W PSU could easily power that.
  2. YAY! Second HD5850 here I come! :P
  3. Its a good PSU and more than enough for your need.
  4. Hi.
    Here are the power requirements for the 5850
    ATI Radeon™ HD 5850 System Requirements
    PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
    500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors recommended (600 Watt and four 6-pin connectors for ATI CrossFireX™ technology in dual mode)
    Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
    Minimum 1GB of system memory
    Installation software requires CD-ROM drive
    DVD playback requires DVD drive
    Blu-ray™ playback requires Blu-ray drive
    For an ATI CrossFireX™ system, a second ATI Radeon™ HD 5850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
    The recommended PSU is for the entire system, so, yeah ur current PSU is more that enough.
  5. Thanks guys :)
Homebuilt Corsair Power Systems
