well this started out as a upgrade for my hp with a MCP61PM-HM (Nettle3) mobo and the amd phenom 9500 2.2 ghz i finally switched to windows 7 64bit and only had 3 gb of ddr2 pc2-6400 and a geforce 8500 gt which came with the comp
i was planning on going to 8gbs of ddr2 pc2-8500 and i was thinking the gtx 480 intill i found out my mobo sucks and doesn't support oc'ing so my techie friend said that it would be a waste because the mobo and cpu would just bottleneck the whole operation so he and a few online forums said i should just biuld a new comp and im fine with that but i unfortunately have to replace all the brake and tire on my jeep so im just going to build a new pc around Christmas
so i thought id spend alittle cash intill them on this nettle3 comp so i replace the two 512 mb sticks that came with the comp to two 2gb sticks for a total of 6bgs
now ive foudn out about the gtx 460 which wasn't out yet when i was first planning to upgrade
now on a few reviews ive seen people are saying two of these in SLI run better than a single gtx 480 while also using less power and makes less noise/heat so would it be a good decision if i bout one gtx 260 now and just ran it on my nettle3 mobo
and come Christmas when i biuld my new pc i was going to buy another gtx 460 and run then in SLI
so do you think this is a good idea also i have a 400 watt power and gtx min is 450 so if i do buy it should i just buy the the power supply for my Christmas comp >800-900W< now and use that in my nettle 3 till i get my new one?
