APPROXIMATE PURCHASE DATE: 1 Week - 1 Month
BUDGET: This is close to my maximum budget ($2100ish.) The monitor does make up 1/4 of the cost, so I might consider less expensive 1920x1200 options that meet my needs (See my other post here.)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Software Development with the ability to game on the highest settings. System to last several years with minimal upgrades. (i.e. Ability to add a 2nd Geforce GTX 470 at some point)
PARTS NOT REQUIRED: keyboard, mouse
PREFERRED WEBSITE(S) FOR PARTS: newegg, amazon
PARTS PREFERENCES: Intel, nVidia
OVERCLOCKING: Maybe SLI OR CROSSFIRE: Eventually
MONITOR RESOLUTION: 1920x1200
ADDITIONAL COMMENTS: Worried about heat, noise and the future like everyone else. Also want to make sure the graphics card will fit easily in the case with enough clearance and airflow (especially after adding a 2nd.) Where could I possibly skimp to save some $$$ without losing out on performance.
Thanks in Advance!
MOBO ($190): ASUS P7P55D-E Pro - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
CPU ($279): Intel Core i7-860 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
HSF ($27): COOLER MASTER Hyper 212 Plus - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
GPU ($378): EVGA GeForce GTX 470 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130549
OR
GPU ($399.99): GIGABYTE Radeon HD 5870 1GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16814125316
HDD ($225): Intel X25-M 80GB SATA II (System drive with an existing 500GB drive) - http://www.newegg.com/Product/Product.aspx?Item=N82E16820167023
RAM ($280): G.SKILL Ripjaws Series 8GB (4 x 2GB) - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231279
CASE ($100): COOLER MASTER HAF 922 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
DVD ($22): LITE-ON 24X DVD Writer - http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
PSU ($140): CORSAIR 850W - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
OTHER ($10): Arctic Silver 5 Thermal Compound - http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
MONITOR ($548): Dell UltraSharp U2410 24" LCD - http://www.amazon.com/Dell-UltraSharp-U2410-widescreen-DisplayPort/dp/B00302DNZ4/ref=sr_1_1?ie=UTF8&s=electronics&qid=1273604533&sr=8-1
OR
MONITOR ($400): 2x Asus VH242H - http://www.newegg.com/Product/Product.aspx?Item=N82E16824236052
Thanks in Advance!
OR
OR
